Inventor Forum
Wont identify contact between two surfaces
8 REPLIES 8
Message 1 of 9
emmagannon
699 Views, 8 Replies
The part I'm making was orginially a .stp file, and I'm using this file to make a concept of the original. My issue is that I need to make a fillet so the connection between the extruded rectangle and the bottom and wall is smoothed out.
However the extruded rectangle I made on the part wont identify that it is joined.
This isnt the first adjustment I've made to the part, so I dont understand why its suddenly doing this now.
Is there a reason for this???
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: emmagannon
I suspect you are trying to fillet a surface body to a solid body.  (Delete Face is almost always used incorreclty by beginners).
Zip and attach your file here.  (or at least expand the surface body folder and highlight the surfaces by ctrl selecting to grab your screen capture)
Message 3 of 9
JDMather
in reply to: JDMather
Yes, this is quite a mess now.
I recommend setting this project aside for a while and go through these
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
And install the Service Packs and Updates for your release of Inventor.
Message 4 of 9
emmagannon
I'm not sure exactly what I'm looking for though, I'm not sure what the problem is.
Message 5 of 9
JDMather
Expand the Solid Body and the Surface Body folders at the top of your feature browser.
Right click on the Surface Body and turn off Visibility.
What you are trying to do is fairly advanced level editing.  I suspect you are about 6 months of studying away from editing this part.
It might be easier to simply create it over from scratch than trying to edit the existing geometry.
Message 6 of 9
emmagannon
Ah, I see the problem. Thanks for your help!
Message 7 of 9
johnsonshiue
Hi! If you want, please move EOP to the top and then save the file. post it here or send it to me directly (johnson.shiue@autodesk.com). I would like to take a ckoser look at the model. Thanks!
Software Test Engineer
Message 8 of 9
johnsonshiue
Hi! I think I know where the problem is. The issue here is that solidbody "70" has been converted to a surfacebody "70" due to the various Delete Face features on the body. These features remove faces from the body and the solidbody becomes a surfacebody. As a result, solid Extrusion22 does not merge with the surfacebody "70." To prove my theory, you can suppress or delete the "Delete Face" features under surfacebody "70" and then you will see the surfacebody "70" will become solidbody "70" again. You will need to edit Extrusion22 and change the solid it operates on.
Thanks!
Message 9 of 9
emmagannon
in reply to: johnsonshiue
thanks johnsonshiue!
