Inventor Forum
Won't Recognize Profile from Projected Geometry
15 REPLIES 15
Message 1 of 16
969 Views, 15 Replies
This must be an easy question, but it has haunted my for a while... I
searched old NG posts and Mymcad but didn't find any answers.
I have difficulty getting the extrude and revolve commands to recognize
profiles involving projected geometry. If the sketch has lines that extend
beyond the profile I am looking for, then IV rarely detects the profile. I
often have to resort to drawing additional lines on top of the projected
geometry(ugh!) to get the profile to be recognized.
I have put a small example of this in customer files. It is two disjointed
cylinders with a sketch located on a plane running through the axes. I
projected the top and bottom faces of both cylinder features, projected in
the center axes of both, and connected the ends of the projected top/bottom
faces with lines. I want a rectangular profile bounded by the top and
bottom of the cylinder features and their projected center axes. I have to
a) draw a line from the midpoints of each projected cylinder face on top of
the projected axes or b) change projected axes to normal, unassociated,
geometry and trim them before a profile will be recognized. That just
doesn't seem right. Is there a setting or trick I'm missing?
Mark Case, P.E.
Sr. Mechanical Engineer
CaseCAD Engineering
(509) 773-7305
web: http://w3.gorge.net/casecad
15 REPLIES 15
Message 2 of 16
mgilman
I run into the same problem......dunno what the solution is, but would really like to find one.
Message 3 of 16
Well ... since profiles have to be closed before they will extrude, the way
I usually do something like that is project the top of one cylinder and the
bottom of the other. Then project the axes'. Next use the rectangle tool to
make a rectangle and use the collinear constraint to constrain it to size.
~Larry
"Mark Case" wrote in message
news:50C771F6085E23060F1C3CDE8B3880CC@in.WebX.maYIadrTaRb...
extend
I
disjointed
top/bottom
to
of
> Thanks
> Mark Case, P.E.
> CaseCAD Engineering
> (509) 773-7305
Message 4 of 16
Larry,
Thanks for the reply.
I usually do something like that too, but it turns out to be a lot of work
on a more complex sketch--my example was VERY simplified. I am expecting it
to work like, say, the bpoly/bhatch command and find the boundary for me.
The method you suggest(and I currently use) results a hodge podge of
overlapping geometry and constraints -and- is time consuming.
Mark
"Larry Caldwell" wrote in message
news:903AE6D74015F080C557B7C60B43FB72@in.WebX.maYIadrTaRb...
way
the
to
> ~Larry
Message 5 of 16
It does overlap the lines but naturally they can be deleted as you know. If
it was one piece projecting the face is real quick but that's not always
bulletproof either. Don't know how one would go about making reference
geometry resize and constrain itself, though, since the idea of reference
geometry is to remain fixed.
~Larry
news:5AE545C7D72D089FBC6FB72951086203@in.WebX.maYIadrTaRb...
> Larry,
it
> Mark
> way
> the
> to
size.
> > ~Larry
Message 6 of 16
Well Larry, it doesn't seem like I touched a nerve with this one. I was
hoping to get a better handle on what IV needs to detect a profile. If you
draw four overlapping lines(as for tic-tac-toe) it won't recognize the inner
square as a profile, but if you trim two of the lines so their endpoints are
on the longer lines it will?
I guess I won't beat this horse anymore, except to request an iPoly command
to make creating the extra geometry quicker...
Mark
news:632490CF72F542A584C920F709D27189@in.WebX.maYIadrTaRb...
If
> ~Larry
Message 7 of 16
Then you wouldn't be using projected reference lines anyway. So now you want
another command to draw the thing with? You can draw a rectangle and dim it
to the origin; can't see a reason for duplicating the rectangle/polygon
tools command with another redundant one, can you?
~Larry
news:346388066BBB9A47C9D27FBD7A901B04@in.WebX.maYIadrTaRb...
you
inner
are
command
> Mark
> If
reference
> > ~Larry
Message 8 of 16
Larry,
Why, yes, I can see the need for the extrude/revolve command to be smarter
at detecting profiles, and/or for some faster way to create whatever
geometry is necessary for a valid profile. Obviously this would NOT be
required for a regular polygons, but for irregular polygons formed from the
projected edges of multiple features or parts. This is more important when
working with projected(associative) geometry because it cannot be altered to
create a 'valid' boundary.
I'd settle for an explanation of what extrude/revolve requires to detect a
closed profile. I just did a couple of tests and it fails to detect a
profile when all of the vertices are not coincident another member of the
group of geometry forming the boundary. Is that the requirement? The iPoly
feature/method would(like bPoly and bHatch) find a profile from ANY geometry
that forms a closed area.
Mark
news:F4F2465AA1BEB789CBB83AB76DA3E973@in.WebX.maYIadrTaRb...
want
it
> ~Larry
Message 9 of 16
It does the same thing in Inventor if I understand what you are saying. If
you project a face it will give you a closed loop of that face and you can
extrude it from there without adding or subtracting anything (there are some
exceptions that I've seen mostly with splines, I think, that can whack
sometimes). A loop will also close on projected reference lines where the
end points aren't coincident if you have other (drawn) lines with coincident
constraints somewhere on the projected geometry. In that case (thinking of
our example) the geometry would only have two projected lines (end points
not coincident) and don't intersect the drawn lines except where the
coincident constraints are. A closed loop means just that: no breaks in the
profile and Sketch doctor will find them forthwith if they exist. A closed
loop is required to make a solid, but you can extrude a surface from an open
loop, depending on the technique you are using. If other geometry is needed
to honor the design intent then it can be added as needed. I routinely
ignore overlapping lines and haven't seen any problems with it. That was at
the root of my suggestion before about constraining the rectangle or
whatever shape to projected geometry. I use as many constraints as I
possibly can to minimize the number of dimensions required and I'm not sure
what the "iPoly" would do that can't already be done the way IV is set up at
present. Do I understand what you are saying correctly?
~Larry
news:61B299B0B22CCF69732D57BEF7ED94A9@in.WebX.maYIadrTaRb...
> Larry,
smarter
the
when
to
iPoly
geometry
> Mark
> want
> it
> > ~Larry
Message 10 of 16
I may be misunderstanding all this myself, but ... I think what Mark may be
looking for is a equivalent of the vanilla "Boundry" command.
If you aren't familiar, put a clothespin on your nose and open AutoCAD.
Draw two overlapping circles and then type in -boundary and select in the
area shared by the two circles. Now type in Move and do a crossing window
of that area... you should have ahold of a shape the same as the shared
area.
In derived sketch modeling I could see the value in a tool like this.
Oh... yeah... wait 15 minutes and then remove the clothespin
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Larry Caldwell" wrote in message I'm not sure
at
Message 11 of 16
Lucked out this time, already know about boundaries, just forgot because I
don't have any close pins probably. If that's what he's talking about,
something similar to that might come in handy. I was thinking he wanted
projected reference lines to ... what ... change their size to make a closed
loop I guess, but then they wouldn't be reference lines any more. I can see
where window picking the rectangle to create a boundary of the enclosed area
would be useful in several areas. See ... AutoCAD mentality ain't bad all
the time I guess.
~Larry
"Kent Keller" wrote in message
news:2DC17513A3C4C2CBDCDD98AAC28D8774@in.WebX.maYIadrTaRb...
be
the
window
> area.
> Kent Keller
up
> at
Message 12 of 16
OK Larry 😉 Now were talking. Thanks for the nudge and the color(er..odor)
Kent.
Often, the profile I am trying to extrude is based on several segments
projected from several different features, that are then spliced together
with a few arcs and/or lines to form a closed area. Unfortunately the
reference(projected) lines are often longer that what is needed for the new
profile, hence the need to add 'extra' geometry on top to allow a profile to
be detected -or- for the profile detection to work like bPoly does.
I have an example of exactly what I'm talking about, but it's based on the
Feb. modeling challenge, so I won't post it until tomorrow. I don't want
taint challenge by posting my version before the deadline...
Mark
news:4A89A7D81B270C3B0B32C84698E4DB7D@in.WebX.maYIadrTaRb...
closed
see
area
> the time I guess.
> ~Larry
Message 13 of 16
Oooh ... which reminds me Peer told me to get off my duff on that so I guess
I better get to it.
I can see what you're suggesting, and it sounds like it might be worth while
in certain circumstances, although I'm not sure how much time it would
really save if we were counting seconds. I can see a profile coming out fine
if the projected geometry is too long, but what would happen if the
projected geometry is too short, and would the projected profile be
reference or normal? The way it is now, normal geometry doesn't
automatically constrain itself to the origin, so if the geometry is normal
then it would still need to be dimensioned to the origin; if it's reference,
then we're back to the same problem as before unless the enclosed profile is
the exact shape you want and wouldn't require any modifications.
~Larry
news:5677F76BA9C528D6722E10F30F93537F@in.WebX.maYIadrTaRb...
> Kent.
new
to
> Mark
I
> closed
> see
> area
all
> > the time I guess.
> > ~Larry
Message 14 of 16
OK, it's posted in CF
To illlustrate my point, I created a single shared sketch to define the web
with the "T" shaped cross section and the open area in the center of the
part.
I posted threee *.ipts in three different states:
1) beforeprojections.ipt -- Contains all of the sketch geometry that
cannot be projected from existing features.
2) geometryprojected.ipt -- This version is what I would expect IV to
recognize a profile from. I projected in all of the geometry that is at
least partly coincident with the boundary and added three lines to fill in
the gaps to form a completely constrained, closed, area bounded by lines and
arcs. Someone afflicted with AE(AutoCAD Envy) would expect this to be
sufficient to define a profile for extrusion. I'll admit life would've been
a bit easier if I'd modeled the holes in the cylindrical features and
projected their edges into this sketch.
NOTE: AE is a less chronic condition than IC (Inventor Cheerleader.) I am
afflicted with both.
3) withextrageometry.ipt -- This version has about 10 extra lines drawn in
and (automatically) constrained to the underlying reference geometry, so
that the outer profile is recognized by the extrude command.
I can see from looking at this month's winner that ONE way to avoid this
situation is to put everthing possible in to a single sketch and then the
projected geometry isn't required(for this part anyway.) Nice job Jayson!
Mark
Message 15 of 16
DDMNTY
Try projecting cut edges while "slicing graphics"
Message 16 of 16
Mark.Lancaster
in reply to: DDMNTY
Why are you responding to a 12 year old posting?  Half the people that have replied are inactive..
Mark Lancaster
