Inventor Forum
Wishlist item
16 REPLIES 16
Message 1 of 17
235 Views, 16 Replies
Wishlist item
For some future version of Inventor I have an idea:
I'd really like a dialog box that would be for driven constraints. What
I'm thinking is that although you can drive any constraint that you
place, most of the time I find myself driving only 2-3 per assembly, and
when building the assembly I'm always wanting to move my parts through
their motion so I can see how it is operating. But, it's kind of a pain
to find the driven constraint, pick the drive constraint option, then
play it. Equally a pain is to grab the item (with the driven constraint
supressed) and drag it around the screen because inventor sometimes
moves the part around erratically, and it's difficult to stop it at
discrete locations, like end of travel of a cylinder.
My proposal is like this:
driven constraint 1 : min |--------[]-------| max
driven constraint 2 : min |--[]-------------| max
driven constraint 3 : min |--------------[]-| max
That way, once you start to use a constraint as a driven constraint, you
can bring up this dialog box and slide the slider bar to move the part
from it's min-value to its max value. Plus, since all the driven
constraints would be on the same dialog box, you could, say, extend and
retract cylinder 1, then swing open and closed door 2, etc, etc, from
the same box to see all the moving parts from the same dialog box.
Thanks.
-Jason
d
16 REPLIES 16
Message 2 of 17
Great idea. I never thought of that but shure would be a very nice
addition.
"Jason M" wrote in message
news:A411846DE07B3715AA9C3D0D44AF513E@in.WebX.maYIadrTaRb...
> Thanks.
> -Jason
> d
Message 3 of 17
Jason:
I like it. Perhaps, just like you can RMB on a part in the browser to
make it grounded, you could RMB on the constraint and elevate it to a
driven status, thus flagging it as being available in your dialog box.
Richard
> Thanks.
> -Jason
> d
Message 4 of 17
Hear, hear old boy! Sounds like a (Edited by Moderator) fine idea to me.
I agree with Jason - Autodesk might like to consider putting it in Inv9
Duncan Anderson
Message 5 of 17
Sean. Kent. Neil, Charles You guys listening? 😉
MattH
Message 6 of 17
Hmmmm do I need a break from the project that is beating me up 8^)
Might take a look at it.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"MattH" wrote in message news:f194e2f.3@WebX.maYIadrTaRb...
> MattH
Message 7 of 17
I particularly like the idea of creating constraints with minimum and maximum limits regardless of whether they are driven or not. Often, there is more than one solution to a constrained part such that it can 'flip' to the wrong one. For example, if you have a cam with a roller follower driving a plunger, the follower will sometimes flip to the wrong side of the cam (so that the cam is cutting the plunger). If a min/max constraint could be applied to the position of the plunger, it could not flip to the wrong side.
Message 8 of 17
Hi Jason,
Great idea!
From day 1 I have wanted to add more functionality to the driven constraint
area of the product.
In addition to your slide GUI idea, I wanted to add a conditional scripting
capability to allow simultaneous and inter-connected constraint drives too.
Hopefully we'll see all of these in a future release!
Gary R. Smith
Inventor Team
Portland, OR
gary.r.smith@autodesk.com
Message 9 of 17
scripting
too.
Hmm, seems we have done that for you...
www.sdotson.com/animator.asp
Wanna buy it? (no I'm serious)
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Gary R Smith (Autodesk)" wrote in message
news:3F4B03675D9D7312FC4C2C080C902249@in.WebX.maYIadrTaRb...
> Hi Jason,
> Great idea!
constraint
scripting
too.
> Gary R. Smith
> Inventor Team
> Portland, OR
Message 10 of 17
Amazing, eh Sean?
~Larry
"Sean Dotson" wrote in message
news:4AF775815ACAF33011E27E3EAD05F8C8@in.WebX.maYIadrTaRb...
> scripting
> too.
> Sean Dotson, PE
> > Hi Jason,
> > Great idea!
> constraint
> scripting
> too.
> > Gary R. Smith
> > Inventor Team
> > Portland, OR
Message 11 of 17
Kent I have about 1/2 the code written for this already.
Could be interesting...
Sean Dotson, PE
"Kent Keller" wrote in message
news:F37F2970AD34D961E6F27C9B7F446532@in.WebX.maYIadrTaRb...
> Kent
> Assistant Moderator
> > MattH
Message 12 of 17
I am about 3/4 the way there. 8^)
Kent
Assistant Moderator
news:A60B4AD0D6AD96BAC40E87A7A7F468E5@in.WebX.maYIadrTaRb...
Message 13 of 17
Why don't you leave some of the fun for the rest of us?
Sean Dotson, PE
news:DE11A89A07E8448B77732459F764CDB5@in.WebX.maYIadrTaRb...
> Kent
> Assistant Moderator
Message 14 of 17
Okay...
If everyone is having so much fun with my idea, when can I have a plugin
to use on my workstation?
-Jason
> Sean Dotson, PE
>>Kent
>>Assistant Moderator
Message 15 of 17
If you are willing to "Beta" test ... pretty much any time you are ready. 8^)
Kent
Assistant Moderator
news:F82663C2B08154EFD0CFB404834CE497@in.WebX.maYIadrTaRb...
> Okay...
> -Jason
Message 16 of 17
I'm willing... where can I download, and how do I install it?
Thanks!
-Jason (email me jmadison AT fthr DOT com)
> Kent
> Assistant Moderator
>>Okay...
>>-Jason
Message 17 of 17
I have added the program to my iCode page
http://www.mymcad.com/kwik/iCode/icode.htm
It turned out to be a bit more involved than I originally thought, and
has a couple of issues I am still looking into, as outlined on the web
page.
Keep in mind it has had very little testing time, so please let me know
if you run into any problems.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
