Josh,
Thanks for your feedback. I logged your wishlist to our tracking
system.
KVK (Test Engineer)
wrote in message news:5006949@discussion.autodesk.com...
I have seen this wish before, but since I'm on the newest IV version now, I
thought I'd throw this against the wall again.
It would be great if Custom iParts would update table columns with custom
values and any calculated columns would use these custom values.
A good example of this is a calculated Part Number column that uses the
custom LENGTH property and the Excel CONCATENATE function. Assuming the
LENGTH was in column A, then the function would be
=CONCATENATE("default part #", " ", A2)
Currently (IV10 sp2) the iPart child always has the same calculated Part
Number as the iPart Factory. If all the column functions were updated when
the user selects "Compute Row", then the calculated Part Number would update
to the correct part number.
