In the Dimension Tolerance dialog that comes up when you double click the
dimension,
I would like to see a check box that would put the diameter symbol in front
of the dimension.
It could be placed next to the "Model Value".
When I am dimensioning sectioned view and adding tolerances, you have to go
to the Dimension Tolerance dialog for tolerances then right click dimension,
click Text, click in front of <<>>, click Insert Symbol down arrow then
click diameter symbol to add a diameter symbol. It would be a whole lot
easier to add the diameter symbol while in the Dimension Tolerance dialog.
My 2 cents worth,
David Lloyd
