Hi all,
I have succesfully placed pins on parts, authored connections, and then placed them into an assembly and wired them up in Inventor 2014 in the past (without problems, up until today). Now, it seems I can create a pin on a part (in the .ipt file), but when I then place that same part into my assembly, the pin is nowhere to be found. I can double-click on the part, and that takes me back to the .ipt file, and sure enough, there's the pin. I can't figure out what I'm doing wrong or differently from when I didn't have this problem! Any advice would be much appreciated.
Hi I was wondering how you solved the problem of the pins not appearing in the assembly. I have the
same problem, and would appreciate the help.
Thanks Dfalk
