Hi, All
I need to attach a ribbon cable hard soldered to a PWA and the opposite end, obviously to an IDC connector set up on the same pitch as the ribbon cable. Unfortunately the PWA connection pitch is larger that the ribbon cable. Is there a sort of mixed mode for connecting a ribbon cable to two different wire pitch connection groups. As a work around I have used discrete wires, but that is not quite elegant.
Al
