Inventor Forum
Wing profile linking points
3 REPLIES 3
PiotrekL1
607 Views, 3 Replies
Hi
I have prepared NACA profile from the generator. I have the set of points but I don't know how to connect them at once. Is there a possibility to use that without any macros?
Cheers
3 REPLIES 3
JDMather
in reply to: PiotrekL1
You can set Inventor to connect the points with a spline on import
or
use the Equation Curve directly.
PiotrekL1
in reply to: JDMather
Hi
Thanx JD, it was so simpleSmiley Very Happy
I have one more issue with it. 205 dimensions required...... How do you dimension such kind of construction
Cheers
JDMather
I see you elected to use the non-parametric import of points rather than the built in parametric Equation Curve method.
Add a construction line to the sketch.
Turn the sketch in to a Sketch Block.
Add Coincident constraint to origin and a Horizontal constraint to construction line.
Now fully constrained (but not parametric).
