Inventor General Discussion
Active Contributor
0 Kudos
Post 1 of 4
Will iPart or iAssembly do this?
627 Views, 3 Replies
09-18-2012 02:45 PM
A lot of layouts I work on utilize tube style augers (screw conveyors).
The general gist of the screw conveyor is once you lock down the inlet and outlet the rest falls into place and a spec sheet can be generated to send off to the vendor.
I would like to create a detailed screw conveyor assembly model (call it a master model) that can be copied, given a unique number and assembled into a layout. I then would like to constrain both ends (inlet/outlet) of the screw conveyor and have it shrink or grow to fit.
This would be the preferred method as opposed to typing in variables to generate the screw THEN place it in the assembly. I would rather have the assembly drive the variables of the screw.
Can someone give me ideas of how this can be accomplished? Would iPart or iAssembly work for this? Any tutorials or links would be great too!
I have attached an image showing the basic specs I need to order a screw conveyor.
Thank you.
*Expert Elite*
2,132 Kudos
Post 2 of 4
Re: Will iPart or iAssembly do this?
09-18-2012 03:16 PM in reply to: conbuc
I think I would use Multi-body solids with iLogic and then only push out to assembly if needed.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Product Support
46 Kudos
Post 3 of 4
10-04-2012 03:20 PM in reply to: conbuc
Hey Conrad,
Did JD's solution get you in the right direction?  The iLogic portion will give you the conditional variations you need for the part file and then the multi-solid body (MSB) workflow would give you the assembly followed by the spec sheet (drawing) creation.
If you are using Vault, you could use copy design to speed up the process after the first spec sheet is completed.
Andy
Active Contributor
0 Kudos
Post 4 of 4
10-04-2012 03:23 PM in reply to: AndrewSears
Hello Andrew,
At first glance I was confused by JD's reply and really haven't had a chance lately to work with it. However between his reply and your reply I believe I should be able to figure it out. I hope to get back to that "side project" next week. I will be sure to post back what I find.
Thanks for your help.
Regards
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
