Thank you for your patience as we transition from the Autodesk Wiki online Help pages to a new online Help environment. In this new environment you should enjoy improved performance and search options, along with a fresh new look.
Once the new learning environment is online, you will be redirected to it automatically when you access the Help from within your Autodesk product.
We are excited to bring this new learning environment to you and we look forward to your participation and comments. Stay tuned for our announcement when the new environment goes live.
Thanks and Regards,
The Mechanical Design Learning Experience team
Thanks Jeanie,
Being one that was in that EE closed door meeting with you, it will be exciting to see the items we discussed implimented.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Online help is great EXCEPT for us folks who spend a lot of time in the field working on laptops with no access to the internet.
Thank you for you comment! You can download the help for Local use here:
R2014 http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16463987
R2013 http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=21310054
R2012 http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18715627
After installing, If you always want to access the local help from within Inventor, you can modify the helpids.xml file located at:
C:\Program Files\Autodesk\Inventor 2015\Bin:
Change the default value - UseOnline="1" - to - UseOnline="0"
The value '1' - This will always launch the online help by default
The value '0' - This will always launch the local help by default
Please let me know of any questions/concerns,
Thank you,
Jeanie Wayker
This is good to here but I do still see this screen way to often.
Then again, this looks much nicer.
We are experiencing some performance issues on the site due to extremely high traffic and content volume and are working on some infrastructure upgrades to handle the situation. We hope to return the site to high performance soon. We appreciate your feedback.
The new online environment should address these issues.
Thank you, and again I am sorry these problems are occuring.
Jeanie
Performance issues??? Ya Think???
Why is there no way to download the tutorials (not the data set -- the actual tutorial text)?
Hello! The Tutorial text IS included in the downloadable help. Please let me know if this resolves the issue for you.
Thank you,
Jeanie
When I'm in Inventor 2013 Pro and hit F1 I still go to WikiHelp? Do I need to do anything to get to the new help site?
Hello!
The new help site is not yet aviailable - We expect it to go live in October. Please stay tuned!
We will send out an announcement when it is Live!
We apologize for the issues with the current state of the wiki.
Thank you,
Jeanie
One more note: When the new site is live, you will be directed to the new site from within Inventor. There is nothing you need to configure.
Please let me know of any other questions.
Thank you,
Jeanie
Come on Autodesk - what do we do NO WIKI-HELP, NO AUTO-REROUTE to the new help
How about you just issue a hotfix so were all singing from The same hymn sheet.
Thank you for your post and we apologize for this inconvience. We are doing everything we can to resolve the issues with the wiki AND we are also working to have the learning enviroment LIVE as soon as possible.
We encourage you to download the local help and set the local help as your default until we have transitioned to the new learning environment. As soon as the new learning environment is live, we will make an Announcement.
C:\Program Files\Autodesk\Inventor 2014\Bin:
Again, we sincerely apologize for this inconvenience.
Thank you,
Jeanie Wayker
Autodesk needs to learn how to make website improvements without loss of service.
"... improved performance and search options, along with a fresh new look."
Dear Autodesk,
This applies to all of your software, interfaces, and web sites: Skip the "fresh new look" part. Entirely. We don't care about the look. Seriously, we don't. Make it work better.
Dedicated users everywhere
I couldn't agree more.
Looks are ALWAYS secondary to performance.
Not exactly. The "look" is always important when you are using a graphical user interface. If the look is garbage, then the UI is garbage, which makes it difficult to work. For example if a work process involves clicking three buttons, and they are at the top of screen, bottom of screen, and on a floating palette, the look certainly impacts performance. Same thing with a help system - how difficult will it be to find things if there is no table of contents?
Personally I'll take something that is harder to find or navigateover something that flat out doesn't work anyday.
