Time and again in my class I refer the students to the wikihelp and it just isn't working.
Next year I am going to ask IT to install local help (if available).
Looks like it will be
http://usa.autodesk.com/adsk/servlet/index?id=16463987&siteID=123112
Hello
Unfortunately right..
Below a link to Ideastation : "Usable online helps"
Vote/Kudo for it in order to push it in first line and put pressure on Autodesk
http://forums.autodesk.com/t5/Inventor-IdeaStation/Usable-Online-Helps/idi-p/3923752
@miechh wrote:
On april 14th 2013, kskent stated:
"We are experiencing high volumes of traffic on the Wikihelp, which are causing intermittent access issues. We are actively investigating solutions to significantly improve this experience".
The response seems to convey that never expected to experience a high volume of traffic for an online help site!!!
I guess they didn't expect the millions of users to actually try and use the help.
Yep, but setting up a bunch of web servers should have a so ridiculous cost compared to subscription fees, that it's not acceptable that autodesk doesn't lift a finger to fix this situation.
that why, i think we have to put pressure on them.
regards,
Aurelien
Help services isn't the only expense of the operation...
Please see the post on this thread:
@Kskent,
look at post #22 of this topic
it sounds that (bad) user experience is exactly the same as before...
As somebody here said, it's like that Autodesk didn't expected such a success for it's online help system and hasn't scaled infrastructure consequently
You do realize "not changing anything" would leave help as online, right?
Guess you did not read it..
I put to fix the help.....
I also put to roll it back to when Inventor worked that would include putting the Help back where it was. I do not understand why the changed it. It was an awesome help before..
I guess they don't understand if its not broke don't fix it..
