Hi Leo
I have the settings the other way around - second monitor has smaller
resolution than primary display on laptop.
I had similar trouble in the beginning - especially when running
presentations, where the laptop took over control.
I guess you run Windows XP. I run XP with the driver 44.82. I have pretty
good results now, and just tested that your resolution also should be
covered. Which driver are you running?
Best regards
Uffe Bak
Autodesk Nordic & Baltic
"Leo Laimer" wrote in message
news:4039af87$1_1@newsprd01...
> Charles,
> As I see you are running a M60 at 1600x1050, same as me.
> My desktop monitor is a 1900x1200 TFT and when I attach this desktop
monitor
> to my M60, I have no chance to set the secondary monitor to the desired
> 1900x1200, 1600x1050 seems to be the maximum. So I can't use the desktop
> monitor with my M60 with good results.
> Do you know any trick, dam I missing something here?
> Regards,
> Leo Laimer
> Bad Ischl - Austria
