Inventor Forum
wich kind of welding???
7 REPLIES 7
Message 1 of 8
824 Views, 7 Replies
I have a problem, I've got a UNP 240 and a sheet metal what needs to be welded on to the UNP. I tried all the welding options but I can't get it how I want. It needs to be a normal fillet weld but that doesn't work.
.iam file added
I need it also to be done at the other end of the UNP
7 REPLIES 7
Message 2 of 8
salariua
The iam itself is not enough. We need the rib plate and UNP as well.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 3 of 8
in reply to: salariua
Do you need all files attached to the UNP?
Here are the 3 that are the main frame
Message 4 of 8
salariua
Still missing some files but I've constrained your plate to the channel. I think you were trying to do it in one step, I've done it in two separate welds.
Please see bellow:
Adrian S.
blog.ads-sol.com
Message 5 of 8
Hey!
Just what I needed! How have you done that? Is there any kind of tutorial for this one? I need to do that a couple times!
Thanks in advance!
Message 6 of 8
salariua
You might want to try the tutorials in help.
For the second weld
Adrian S.
blog.ads-sol.com
Message 7 of 8
Thanks!!
Message 8 of 8
ewemily33
Have you tried laser welding? In this welding laser beam is an intense, highly coherent beam of monochromatic light which has been amplified hundreds of times.
