Inventor General Discussion
Forumhelp2012
Message 1 of 15 (588 Views)
WHY WONT THIS SHAPE EXTRUDE
588 Views, 14 Replies
10-24-2012 07:39 AM
Hello
I am following U-Tube tutorial called "Table plastic video tutorial Autodesk Inventor 2010"
I am up to time stamp 4 minutes. I should be extruding the shape by 1.5 inch.
Although there are lines under lines they are construction lines underneath.
I could do with some help here I can't figure it out why it wont find the part closed to do the extrude.
http://www.youtube.com/watch?v=HV7XZVY94o4&feature=relmfu
I have attached the part too.
Kind regards
A CAD Student.
JDMather
Message 2 of 15 (578 Views)
Re: WHY WONT THIS SHAPE EXTRUDE
10-24-2012 07:59 AM in reply to: Forumhelp2012
You are doing pretty good so far.  But there are a couple of problems.
When I see repeated dimensions like this - I suspect something wrong.
Also, I haven't watched the video yet, but I suspect those arcs and lines are supposed to be tangent.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Cadmanto
Message 3 of 15 (576 Views)
10-24-2012 08:00 AM in reply to: Forumhelp2012
Typically when things don't extrude it is because the sketch is not completely enclosed.
Even though you are saying the lines under the lines are construction lines I would sugest deleting them
and getting a clean enclosed sketch.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
JDMather
Message 4 of 15 (574 Views)
10-24-2012 08:05 AM in reply to: Cadmanto
OK, just watched the video - that person has not particularly experienced.
JDMather
Message 5 of 15 (561 Views)
10-24-2012 08:17 AM in reply to: JDMather
If I take the time to show you the steps to do this correctly, are you going to stick around to follow the instructions?
JDMather
Message 6 of 15 (555 Views)
10-24-2012 08:26 AM in reply to: JDMather
Step 1 create rectangle and then diagonal line as shown.
Then add coincident costraint between midpoint an origin (don't use the horizontal and vertical constraint as shown in the video, it would work and doesn't really matter in this case, but develop a better technique.  In 2013 there is a centerpoint rectangle to do this for you.  For 2012 there is a centerpoint rectangle Add-in avialable somewhere (a Google search should turn up the download link.))
JDMather
Message 7 of 15 (544 Views)
10-24-2012 08:41 AM in reply to: JDMather
Dimension the rectangle with the dimensions as shown.
Add R.75 fillet to the four corners.
Add vertical 7.75 line as shown.
JDMather
Message 8 of 15 (542 Views)
10-24-2012 08:44 AM in reply to: JDMather
Using crossing window (right to left) select these lines and change to construction.
JDMather
Message 9 of 15 (539 Views)
10-24-2012 08:48 AM in reply to: JDMather
On the next step the YouTube shows this arc as NOT tanget, so we'll assume that is the design intent.
Create a 3-point arc at the endpoints of the fillets as beginning and ending point and the the end of the 7.75 construction line as the third point.
JDMather
Message 10 of 15 (523 Views)
10-24-2012 09:22 AM in reply to: JDMather
Now just fun - dimension this arc (it should already be fully constrained).  See where the YouTube got that silly dimension.
Much easier to type 7.75
Create  the same arc at bottom but just click in space for the third point and then make the two arc Equal (=) constraint/.
(don't dimension, don't mirror)
