Inventor Forum
Why welding beads looks plain in Inventor 2014?
7 REPLIES 7
Message 1 of 8
Orest_iy
2527 Views, 7 Replies
Hello, I just tried the weldment in 2014 and welding bead looks plain, like a simple chamfer. Is there any way to make it looks more realistic like 2012? Best regards, Orest Yavtushenko
7 REPLIES 7
Message 2 of 8
Paul-Mason
in reply to: Orest_iy
That's a perfect description of a GROUND/MACHINED BACK weld.
Looking a the tree you have "Machining"  set to show you'll need to either edit the weldment and delete Machining or turn it of to get the "Caterpillar"
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 3 of 8
blair
in reply to: Paul-Mason
This has to do with the appearance for the weld bead, you don't have the "weldcat0.png" selected for the weld material.
You can also use the Material portion and change the Material to "Metal: Welded" or "Aluminum: Welded". These are already setup within the Material.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 8
Orest_iy
in reply to: blair
Does not work here.
I have tried all weld Material from Inventor Library
Orest
Message 5 of 8
samiharada
Weld beads texture is shown when
* You are using either Quality or Performance graphics
  ([Tools] tab - Options panel - Application Options - [Hardware])
* Texture On
  ([View] tab - Appearance panel)
Please note that you have to close all document windows first in order to switch App Options - Hardware settings.
Hope this helps
-Sami Harada
Inventor Framework QA
Message 6 of 8
Orest_iy
in reply to: samiharada
Yes it is working under the Perfomance.
I have enough powered machine but use Compatibility only.
I could see welding texture in the 2012 in the same mode.
Orest
Message 7 of 8
samiharada
May I ask you if there's a specific reason you are using compatibility mode?
-Sami Harada
Message 8 of 8
Orest_iy
Reason one
Under the Perfomance mode it is too dark and I cannot fix it with maximum brightnees of lighting settings.
Reason two
If I rotate the sectioned assembly it makes a whole mess with section, empty (like made of surfaces) solids and etc.
In the Compatibility mode everything works ok.
Orest
