Inventor Forum
Why use Task Scheduler to migrate files?
3 REPLIES 3
iamerm
400 Views, 3 Replies
This is probably a dumb question, but I'll ask anyway:  what is the benefit of using Task Scheduler to migrate all of my Inventor files to the latest versions?
I've upgraded several times, but I've never done a full file migration.  I've read instructions on HOW to do it, but, again, I'm not sure WHY.  Thanks in advance for any input.
3 REPLIES 3
JDMather
in reply to: iamerm
I have never used it before, but -
I suspect an obvious reason to use Task Scheduler is to do the migration why I am at home sleeping (not that I actually do that either).
The CADWhisperer YouTube Channel
Curtis_Waguespack
in reply to: iamerm
Hi  iamerm,
I think the best reason is to improve assembly performance when opening and saving large assembly files. Often when you update an assembly created in a previous version and then make a simple change you'll be presented with the need to migrate all of the component files when saving. This can be time consuming and disrupt the imidiate task at hand.
If you look at step 7 in the "Before you Begin" section of this link, you'll find a few more tools that are often important when migrating:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0000-Installa0/0192-Data_Mig192/0193-Data_Mig193...
Another reason that this can be important, is that as Inventor evolves from new release to new release. So there can sometimes be issues with trying to open a file that was last saved in a version too far back. I don't recall the version now, but I do remember that I have dealt with a bunch of sheet metal files in the past that would not open in the lastest version, because they were last saved 3 or 4 versions back. The solution was to migrate them to a middle version, then bring them forward to the latest version. This all caused a lot of problems until that solution was figured out, and could have been avoided by migrating between each release.
More reading:
I hope this helps.
Curtis
iamerm
in reply to: Curtis_Waguespack
Curtis,
Thank you for your reply.  That info., particularly the last link ("More reading:") you sent, was exactly what I was looking for.
Thanks again.
Eric
