I have quite simple part.
But can not close loop for extrusion.
In attachment you have ipt. inside there is one sketch and first extrusion I did. I want also to do the second one (for 10 symmetric) (you should see from sketch).
This is extremely annoying having to fight with this kind of bugs.
I intended to use this part to insert it in assembly.
Cris.
i too faces these sketch problems very often and its very irritating.
what i do now is-
- i delete those curves which are not coincident or not exdruding (you can see by using extrude command, where curve is breaking)
and than again draw.
but i would like to see any good method for doing this.
For doing what?
You did not attach a file here?
same problem as above.
unable to extrude because points are not coincident whenever doint sketch pattern (for gear teeths look a like sketches.)
and also can not repair through sketch doctor.
Where is the *.ipt file?
My guess (and this is only a guess) is that you did something wrong.
Of course, the file would be required to diagnose the problem with your particular file.
