> Why are some Inventors drawing features so
lame compared to AutoCAD & MDT
> For Example
Why can you not window pick to delete something in a drawing ??
Much rather have control of Tangent
edges line weights and the ability to turn outlines off but window picking for
line visibility wouldn't be bad either.
size=2>
> Why when you try and modify a
set of baseline dimensions do all the other
> dimensions shoot off the
screen into no man's land?
Mine don't ... least I haven't
seen'em do that yet.
> Why do all your dimensions drop off when you haven't even
modified that part
> of the model?
Don't know what that means.
> Why when you want to adjust the offset position of a
group of dimensions do
> you have to do it one at a time?
> Why not
stretch or somthing?
I think it might be because ANSI standard calls for
staggard dimensions but, while I use them, not everyone likes them so
maybe they haven't decided how to please the most users with some comprimose
yet. Also one of the prices you pay for using leading edge software, but there's
no law you have to.
> Some things about Inventor are so good. Example
modeling environment. But
> if you just want to do something quickly in
the drawing is it so painful.
Like what? If you get model dims you can work in the
idw, but for the most part the idw reflects the model.
> I think the developers should find someone that knows how
to use AutoCAD or
> mechanical desktop well and see how
quick it is to construct some geometry. copy, rotate, move previous,
move
> last, match prop, stretch etc....
Thank goodness there's not much chance of iTeam
considering making Inventor into AutoCAD.
> How hard can I be
> R10 AutoCAD could do
all this.
> I am a draftsman a I have used AutoCAD full time for
5 years
> Mechanical Desktop 4/5/6 for 3.5 years
> Inventor for 1
year.
Ah ... that's the reason. <G>
> I believe that Inventor does not make things easier when you
have lots of
> drawings of different parts to produce.
> Sure if you
only have one or two parts and you are just changing a few
> dimensions it
is quick
> But so is AutoCAD in this situation just stretch, copy move
etc.
> What does any one else think ??????????????????
Blaaah! <G>
> Stuart.
