Inventor Forum
Why no rotational freedom?
4 REPLIES 4
rickduley
572 Views, 4 Replies
This cross-head pin is transitionally constrained in the slot.  I can move it within the slot, but I cannot rotate it as I expect.
Can someone please tell me why not?
4 REPLIES 4
CCarreiras
in reply to: rickduley
Hi!
Because transitional is kind of  Sliding constrain.
You can use "Physics conditions": promote a "contact set" between both parts and activate contact solver.
If you move the part manually, it will behave like (or near) the real world.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
JDMather
If you going to get serious about motion (and if you have Inventor Professional), I would take this to Environments>Dynamic Simulation.
rickduley
in reply to: CCarreiras
Hi Carlos
What is that supposed to do?  I cannot discern any difference in the behaviour of the model.
CCarreiras
Hi!
Now the part can rotate also. If you manually grag it, the part can slide and rotate, depending how you pick them. It acts more naturally.
Before, the part only slide thru the walls.
But, in the end, we can say that ist´s the same: the part only moves inside the slot.
CCarreiras
