Inventor General Discussion
Valued Mentor
GSE_Dan_A
Message 1 of 15 (655 Views)
Why is Text Size NOT a Parameter???
655 Views, 14 Replies
03-28-2013 01:17 PM
I have been diving into the world of iParts, iLogic and iLogic Forms and have found them to be very useful! However, I am shocked to see that Text Height is NOT a parameter. The parts I am creating have embossed text.  The size of parts range significantly so the size in text must also change. In making a Form, I would like the Text height to change based on the part being created. (ie if the part thickness is 1.5", I would like the text height to be 1" (Text Height = 66% of Part Thickness).  I was about to create a simple iLogic rule to accomplish this when I noticed that Text Height (from the sketch) is nowhere to be found.  Is there a work around for this?  I have searched the web and some people suggest a macro or VBA (both of which I have never used).
Thank you in advance,
GSE Consultants Inc.
Windsor, ON. Canada
Distinguished Contributor
VdVeek
Message 2 of 15 (621 Views)
Re: Why is Text Size NOT a Parameter???
03-28-2013 11:43 PM in reply to: GSE_Dan_A
You can use this iLogic code to change the text height. It overrides the standard Style.
I created a part with a Sketch named "Text" and a parameter named "textToEmboss" that holdes the text i want to extrude/emboss.
Dim odoc As PartDocument
odoc = ThisApplication.ActiveDocument
Dim osketch As Sketch
'The used sketch name in the extrusion is Text
osketch =odoc.ComponentDefinition.Sketches.Item("Text")
osketch.TextBoxes.Item(1).FormattedText ="<StyleOverride FontSize='0,5'>"+textToEmboss+"</StyleOverride>"
odoc.Update
Rob.
Autodesk Inventor 2012 Certified Associate & Autodesk Inventor 2012 Certified Professional.
Valued Mentor
GSE_Dan_A
Message 3 of 15 (573 Views)
04-02-2013 05:50 AM in reply to: VdVeek
Thank you very much Rob!
I will give this iLogic code a go and report back.
Windsor, ON. Canada
Valued Mentor
GSE_Dan_A
Message 4 of 15 (567 Views)
04-02-2013 06:08 AM in reply to: GSE_Dan_A
Rob,
What if I want to add a condition to this iLogic? Where would I place this?  For example, if Ring Diameter is 0.50 then the text size will be 0.375.
Windsor, ON. Canada
VdVeek
Message 5 of 15 (538 Views)
04-02-2013 11:10 AM in reply to: GSE_Dan_A
I changed the part with the condition (see attachment). You where on the right track when you wrote:  if Ring Diameter is 0.50 then the text size will be 0.375.
This is the way to write a condition:
If parameter Diameter = 0.5 Then
Change the scale of the fontsize: osketch.TextBoxes.Item(1).FormattedText =".............
End If
Rob.
Member
blayfield
Message 6 of 15 (274 Views)
02-28-2014 01:41 PM in reply to: GSE_Dan_A
Quick question... I have a file also that uses ilogic to update the extruded text in a file through a dialogue, I want to be able to control the text character spacing, is there a way I can achieve this?
blair
Message 7 of 15 (265 Views)
02-28-2014 02:32 PM in reply to: blayfield
The only software I know that allows for "kerning" is publishing software. Most Fonts have Kerning built into the Font. It's just having the correct software to access it. I don't know if you can copy text from something like InDesign into Inventor and retain any Kerning adjustments done in InDesign.
IV2015 up2 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
LT.Rusty
Message 8 of 15 (241 Views)
03-01-2014 12:51 PM in reply to: blair
Unfortunately, copy-pasta of text into Inventor does not retain kerning.  I've tried that.  :smileytongue:
This thread actually hits on two of the biggest items on my personal Inventor wish-list: text parameters working in iParts and manual kerning!
___________________________________________________________
Product Design Suite Ultimate 2013, 2014, 2015
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / Radeon R9-270X 4GB
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
blair
Message 9 of 15 (236 Views)
03-01-2014 01:01 PM in reply to: LT.Rusty
I didn't think it would as there is nothing in Inventor to hold the changed Kerning. Maybe convert the "Kerned" text to an image and treat it as a Decal
Win7-64
LT.Rusty
Message 10 of 15 (234 Views)
03-01-2014 01:02 PM in reply to: blair
... except when you need to mill the text.
