Inventor General Discussion
New Member
3 Kudos
Post 1 of 10
Why does the camera turn 180 degrees after selecting top plane
1187 Views, 9 Replies
01-11-2013 04:12 AM
I use inventor 2013. Whenever I start a new sketch and select the top plane, the camera changes so I look at the top plane but also rotates 180degrees. I really hate that the camera rotates 180 degrees because it causes me to always see the drawing upsidedown (and then change the camera... everytime...)
Is there a way to disallow inventor to cause this treason?
Kind regards,
Gerard
Valued Contributor
22 Kudos
Post 2 of 10
Re: Why does the camera turn 180 degrees after selecting top plane
01-11-2013 04:18 AM in reply to: SlechteExcusesMan
Im not sure if this is what you mean, but go to Tools>Application Options>Sketch Tab, and uncheck "Look at sketch plane on sketch creation" towards the bottom on the left.
New Member
3 Kudos
Post 3 of 10
01-11-2013 04:31 AM in reply to: riff62
I do want to look at the sketch plane but I don't want inventor to also turn the camera 180 degrees so my plane is upside down
I've added an attachment. The right part of the image shows what my viewcube looks like after I started a drawing on the top plane, the left part of the image shows what I want my viewcube to look like
Active Contributor
87 Kudos
Post 4 of 10
01-30-2013 10:53 AM in reply to: SlechteExcusesMan
+1.  Asinine problem, been around for years, has a seemingly immediate and simple fix.  Fix the problem, please.
"Idea" post:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Sketch-Orientation-quot-Look-At-quot-Feature/idi-...
0 Kudos
Post 5 of 10
06-26-2013 10:39 AM in reply to: NathanGMartin
I would also like to see this annoying, time wasting problem fixed!
843 Kudos
Post 6 of 10
06-26-2013 10:56 AM in reply to: NathanGMartin
Note the status of the Idea... Accepted.  It usually takes a while to get the fix implemented... annoying as it is, patience my friends.  :smileyhappy:
ChrisB / Twitter
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
Valued Mentor
89 Kudos
Post 7 of 10
06-26-2013 02:07 PM in reply to: SlechteExcusesMan
If it's any consolation, there's a fairly logical reason for the behavior.  (Annoying, yes, but logical.)
Front view: +X-axis to right, +Y-axis up
Right view: +Y-axis to right, +Z-axiz up
Top view:   +Z-axis to right, +X-axis up
Notice a pattern of sequence here?
Yes, children.  That's how it winds up inverted.
843 Kudos
Post 8 of 10
06-27-2013 05:33 AM in reply to: graemev
Um...
View Cube Front - +X-axis to right, +Y-axis up
View Cube Right - +Z-axis to left, +Y-axis up
View Cube Top - +X-axis to right, +Z-axis Down
When new sketch selected on XZ Plane... View Cube Top flips upside down.
+X-axis to left, +Z-axis up
I'm no mathemtician, so I guess I need help understanding the logic.
ChrisB / Twitter
Active Contributor
10 Kudos
Post 9 of 10
06-27-2013 11:53 AM in reply to: cbenner
I have to respond to this. Not to criticize you or even single out this particular bug, but given how much this software costs the amount of time it takes to get fixes implemented is not even in the same GALAXY as passably acceptable. Every time I discover a bug in an Autodesk product, I come to these forums and inevitably discover that the devs have known about it since 2003. And don't even get me started on the price per feature of the tiny annual updates. Autodesk has such a monopoly they've stopped caring even a little bit about their customers. I'm actively testing alternative products/companies and EVERYONE should be doing the same.
Lee Saxon
Ellis Photographic Design
Valued Mentor
89 Kudos
Post 10 of 10
06-28-2013 11:29 AM in reply to: cbenner
Sorry, I was thinking more specifically Sketch than View Cube.  The horizontal axis of a sketch is slightly thicker than the vertical, thus in the Right view (per the view cube) horizontal is "up", and so on.
