Inventor General Discussion
DMRichardson
Message 1 of 8 (533 Views)
Why does ctrl not work?
533 Views, 7 Replies
10-11-2012 03:17 AM
I've not been able to use Ctrl in 2013 (not a problem with any other version).  i've looked at the key mapping, but it's all ok. i've tried that button that fixes the single key shortcuts, that's fine, but no help for my Ctrl.  Any views? maybe it's a windows issue?
Thanks.
David Richardson
Regards
David Richardson
I don't know how it has happened. but it's working again.
As you said, look at keyboard settings i went for a poke around the devices manager.  I have a standard mouse and a very old dell keyboard. no fancy softwear with bells whistles and tickboxes.  all i have done is open up the device driver box and closed it again but it seems to have done the trick! i have no idea why as there was nothing for me to change anyway! oh well.
The gods are on my side today i guess.
David
Mark_Wigan
Message 2 of 8 (525 Views)
Re: Why does ctrl not work?
10-11-2012 05:01 AM in reply to: DMRichardson
hi,
assuming it works with other apps,
does it work in combination with any other command inside inventor eg during copy or paste or is it just when over-riding automatic contraints etc?
best regards,
- Mark
(Kudo or Tag if Solved - it may help others)
PDSU 2015 Windows 8.1, 64bit.
DMRichardson
Message 3 of 8 (521 Views)
10-11-2012 05:29 AM in reply to: Mark_Wigan
Hello Mark,
it seams to be any comand with the ctrl and another key,
eg ctrl z
ctrl n
ctrl c
also slice graphics F7 doesn't work, so i guess i could find more not working in the future. Like i say though, i tried resetting keyboard mapping to no avail.  All the letter shortcuts work (S for scetch)
i've been able to workaround all the problems so far...
David
Regards
David Richardson
Mark_Wigan
Message 4 of 8 (513 Views)
10-11-2012 05:57 AM in reply to: DMRichardson
i haven't heard of this but i haven't looked for it either.
without looking into this i wonder if it could be something like an input device setting that has been configured to recognise a gaming environment, and as such uses defaults other than what you require?
if you are running a high tech mouse or keyboard maybe try going through some settings to see if it has some keu board overides that can be changed?
i recall that in days past for example, you could tell the logitech mouse to sense when it was in a game environment and whether to keep its operating system settings or whether to switch to alternative settings that were able to be defined by the user. if you did not click the option, then the mouse cursor would move extremely slow when inside inventor!
sorry for the guess, i know it is a long shot.
best regards,
- Mark
DMRichardson
Message 5 of 8 (505 Views)
10-11-2012 06:35 AM in reply to: Mark_Wigan
David
Regards
David Richardson
Mark_Wigan
Message 6 of 8 (486 Views)
10-11-2012 07:47 AM in reply to: DMRichardson
you are definately on a roll
best regards,
- Mark
Valued Contributor
cbrownAMS
Message 7 of 8 (287 Views)
07-16-2013 10:14 AM in reply to: Mark_Wigan
Ever since installing Smoke 2013 I've had the ctrl key stop working on occasion. It seems to happen when leaving the screen of the software to check email or do something on a browser. When I come back to Smoke the crtl does not work. Haven't found the work around yet. I'm using a Smoke keyboard that came with our Mac purchase.
LT.Rusty
Message 8 of 8 (265 Views)
07-16-2013 02:22 PM in reply to: cbrownAMS
CTRL works for me in all of my combinations - CTRL-Z, etc. - but it does not work when I'm laying out sketch geometry and I want to keep from forming automatic constraints.  That's incredibly annoying.  It seems to only be an issue in 2013.  2014 at home seems to be working fine, and 2009-2012 seemed to all be fine as well, back when I still used those.
___________________________________________________________
Product Design Suite Ultimate 2013, 2014, 2015
Workstation: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / Radeon R9-270X 4GB
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
