Hi guys,
Having some issues getting the R5 fillet/arc to join the top end of the part to the cylinder that runs down, I tried face fillet but that doesn't give the desired result compared to the drawing.
I am attaching the drawing and .ipt file hoping someone can help me 🙂 Thank you!
Solved by hfds006. Go to Solution.
Hi! hfds006 is right. Based on the drawing, the round cannot be created just by a fillet. You need to apply a revolve cut based on a profile on XY plane or XZ plane just like the views show. You can either make the 5mm round with the revolve or as a fillet after that.
Thanks!
I would have done Sketch3 on the XZ plane and Extrude - Cut midplane through all rather than create a new workplane.
