Hi.
I have trouble launching Inventor Pro version. I installed it about one or two weeks ago and I didn't launch once I had finised installation (Actually I didn't even wait until the installation is complete. The loading became ultimately slow like thousands of days left after some hours of installation. So, I canceled the installation but it shows that Autodesk Inventor 2015 had already been installed (Installation was canceled. some product were not installed, but I saw there was a green tick for Autodesk Inventor 2015 ) and a shortcut appeared in dekstop. I went to autodesk.com again to download the setup for Autodesk Inventor Pro 2015 to see whether I had installed completely. Before that installation started, I wasn't allowed to check the box for Autodesk Inventor 2015 and it just say something like :"if you need language pack...." ). Today when I try to launch it, beside the mouse seemed to load for a while and I saw in Task Manager showed Autodesk Inventor 2015 for a while then it disappeared. Besides these observation, nothing showed up, not even a splash screen. Sometimes when I launch it, the Task Manager shows that Disk-100%.
I used the solutions shown in http://beinginventive.typepad.com/being-inventive/2014/04/inventor-2015-startup-crashes.html , but same situation happens whenever I try to launch.
(I also have DWG True View which was installed about two weeks ago, but I do not have any issue launching it today.)
Could anybody solve this problem?
Thanks!
Hi.
Thanks for reply. I think my main problem is incomplete installation.
Just now I installed service pack 2015 and it still doesn't work.
Now, I wish to know how to uninstall it. When I press uninstall/change button in contral panel, it shows:" An error occured while trying to uninstall Autodesk Inventor Professional 2015-English. It may have laready been uninstalled. Would you like to remove Autodesk Inventor Professional 2015-English from the Programs and Features list?"
I am confused. I didn't even uninstall it before. The proof is in my last message:"... I went to autodesk.com again to download the setup for Autodesk Inventor Pro 2015 to see whether I had installed completely. Before that installation started, I wasn't allowed to check the box for Autodesk Inventor 2015 and it just say something like :"if you need language pack...." ".
So, do you think I should remove it from the Programs and Features list and see what will happen?
Thanks.
Hi.
I used Autodesk Uninstall tool and tried installation again for a few times. Finally, the installation was successful.
Thanks.
