I wonder why it is like that so adaptive sketches can not be shared?
In my particular case I have I-beam and connection plate in assembly. In connection plate there are holes for bolts and slot.
I wanted to make set of holes in I-beam and cut identical slot.
So I had made a sketch on I-beams' web and projected connection plate. So far so good.
But after I make holes basing on centers from sketch and share this sketch I can no use it for extrusion.
Why? I believe this worked in previous versions.
Cris.
