It's been there, just a bit tricky sometimes. Make sure the receiver sub is
expanded, etc.
There's also a way to re-order the browser by dragging into and back out of
sub assemblies, but you loose assembly constraints. If you do want to insert
a batch of parts in mid-browser create a temporary sub in the assembly,
instance in the parts you want, return to upper level, drag the parts from the
temp sub to where you want them and delete the temp sub.
"Jon Genova" wrote in message
news:3E4A9861.B8F28ECD@stripe.colorado.edu...
Well, I'll be....
Jon Genova
Senior Mechanical Design Engineer
BioServe Space Technologies
A NASA Commercial Space Center (CSC)
genovaj@stripe.colorado.edu
Bioserve URL http://www.colorado.edu/engineering/BioServe/
Personal URL http://stripe.Colorado.EDU/~genovaj/
