Inventor Forum
Who do you report a bug to
4 REPLIES 4
mdavis22569
1186 Views, 4 Replies
? ...Who do you report a bug too ... I found an issue with projecting geometry and adding a point to it in a sketch ... on several of my machines and various assemblies. They are all up to date on patches etc ... Mike
Mike Davis
4 REPLIES 4
mcgyvr
in reply to: mdavis22569
"supposedly" this forum is sufficient.. They claim that Autodesk staff is actively looking at each and every message.
Frankly I just use this form http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
mdavis22569
in reply to: mcgyvr
Thank you .... I'll posted what and how I got the bug: I have an assembly of a conveyor frame ( this isn't about how to do something or how you do it post).. I edit model in place for one of the channel stringers in the assembly 1) I Create a sketch on the plane/face of the channel I want to make holes, slots etc... 2) I project geometry of the washer to locate where the hole will end up. The projection is not adaptive, however is projected as a construction line. 3) I try to add a point to the center of the washer center point. it doesn't show up... However 4) If I exit the sketch and come back in, I'm able to add the point now and have it show up. This was possible prior to adding the latest update
Mike Davis
mdavis22569
oh yeah ... Windows 7 IV Professional 2014 build 222, Service patch 1, Update 3
Mike Davis
mdavis22569
Thanks Mcgyvr, I submitted it via your link and in 2 minutes had an email from someone at Autodesk...shot a video showing it and they got it ...thank you for the help
Mike Davis
