Inventor Forum
white pixels in Ray Tracing
2 REPLIES 2
dodrain
682 Views, 2 Replies
In Ray Tracing mode I keep having white pixels, can this be solved?
Settings of Ray Tracing is "Good"
In "Best" it is really slow
2 REPLIES 2
sam_m
in reply to: dodrain
is it me, or are the white splotches only on the glass areas?
if so, have you tried changing the glass to something else (possibly non transparent) and are there still these blobs?  if not then shows it's down to the glass material - try varying the shinyness and/or opacity...
Also... how are the glass panels located in the assembly?  There has always been rendering errors with glass if it is touching (or intersecting) another object - make sure the glass is inside the border and not mated with a zero offset with anything (something tiny like 0.01mm will do).
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
mcgyvr
in reply to: sam_m
So it's not just snowing in the trolley Smiley Tongue
