How can I make a white part appear white in the IDW drawing ? It will show as white decaying to gray or if I turn off the specular color, it appears gray.
Solved by salariua. Go to Solution.
To me it only worked if set self-ilumination on as here:
This may help..
http://inventortrenches.blogspot.com/2011/02/disable-reflections-and-gradients-in.html
and so will making all the color options.. specular/emissive,etc.. being absolute white.
Thanks for your help. It solved my problems. Do you know how to make it work for decals ? There is a color shift as well in IDW. Above solution does not seem to work with images.
did you try my suggestion above?
That should work for decals too.. as far as the color shift/gradients
The registry hack stopped working but can't remember from what version onwards, I think it was 2013 but not sure.
Is it working for you mcgyvr?
