Inventor Forum
White part appearing gray in IDW
6 REPLIES 6
TheCarl
1439 Views, 6 Replies
How can I make a white part appear white in the IDW drawing ?  It will show as white decaying to gray or if I turn off the specular color, it appears gray.
Tags (1)
6 REPLIES 6
salariua
in reply to: TheCarl
To me it only worked if set self-ilumination on as here:
http://forums.autodesk.com/t5/inventor-general-discussion/inventor-2015-drawing-views-materials-shad...
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
mcgyvr
in reply to: salariua
This may help..
http://inventortrenches.blogspot.com/2011/02/disable-reflections-and-gradients-in.html
and so will making all the color options.. specular/emissive,etc.. being absolute white.
TheCarl
Thanks for your help.  It solved my problems.  Do you know how to make it work for decals ?  There is a color shift as well in IDW.  Above solution does not seem to work with images.
salariua
You need to turn sketch visibility on for that model in the drawing browser.
So right click on the model and select Include Model Sketches.
Adrian S.
blog.ads-sol.com
mcgyvr
did you try my suggestion above?
That should work for decals too.. as far as the color shift/gradients
salariua
in reply to: mcgyvr
The registry hack stopped working but can't remember from what version onwards, I think it was 2013 but not sure.
Is it working for you mcgyvr?
Adrian S.
blog.ads-sol.com
