Solved by KevinLi-Autodesk. Go to Solution.
Hi wmd2,
From your description I suppose you use Inventor to create model and want to export to PDF format, right ? If that is case, you can direct hit " I " icon (located at left-up coner) -> Export -> PDF to export.
Kevin Li
Quality Assurance Team
Hi wmd2,
You are welcome and glad to see we help you.
If you meet any data translation problems later you can post it in this forum or contact me via Hongyuan.Li@autodesk.com , we will take a look at.
Have a good day !!!
Kevin Li
