Inventor Forum
Where used in drawing
8 REPLIES 8
Message 1 of 9
alex.dring
633 Views, 8 Replies
Is there a way for me to somehow display what assembly uses a particular part?  For example I would like a part drawing to somehow inidicate what assembly drawing to refer to in order to show quanities required.
Can this be done?  Perhaps with ilogic which I know nothing about but will learn to get this to work. I am currently using standard Inventor 2012.
Thanks.
8 REPLIES 8
Message 2 of 9
blair
in reply to: alex.dring
If you are using Vault, it can be done inside Vault and in you are not using Vault, the the Design Assistant will show where a item is used.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 9
alex.dring
I was actually looking for something that I could stick on the drawing.  Like a variable that automatically updates. It is more for our purchasing department as a check so they know what parent assembly drawing to look at in order to verify the correct quanitites should be ordered.
Message 4 of 9
swalton
There is no out-of-the-box solution in Inventor.
Take a look at the Autodesk App Exchange for Invnetor for some Third-Party solutions.
http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3acpsjob...
http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3aquanti...
I have not used either one.
Good Luck.
Steve Walton
Inventor 2023
Vault Professional 2023
Message 5 of 9
alex.dring
in reply to: swalton
So how does one create programs like that?  Those almost do exactly what I want but instead of quantities I want it to show the drawing and/or part number that the assembly is.
Didn't even know about the app exchange.
Message 6 of 9
swalton
Look into iLogic in the help file.  I don't use it much, but there is a lot of power for automating routine tasks.
I can see making a custom iprop in your part templates, then making an ilogic rule in your iam templates to write the assembly file name/part number to each member of that assembly.  Then make a custom sketched symbol or title block field to show the custom iprop on your drawings.
What happens when you use the same part in five different parent assemblies...
Steve Walton
Inventor 2023
Message 7 of 9
alex.dring
I will look into the iLogic.  Like you said there seems to be a lot of power in that.
For parts that are used in multiple assemblies I think it should just return a value of "Multiple or Various"
So basically you see like a time stamp in the drawing title block "Parent Assembly: (part or drawing number)
Message 8 of 9
swalton
Another thing you might try:
1. Make your part idw.
2. Place a Parts List of the parent iam file in the part idw.
3. Hide all rows of the Parts List execpt the part shown in the idw.
       You can filter the list by design reps created in the iam file.
4. Change the title of the Parts List to show its source iam file.
5. Add a new Parts List for each iam file that uses the part.
Steve Walton
Inventor 2023
Message 9 of 9
alex.dring
Thats a slick little work around swalton.  Thanks.
