Inventor General Discussion
Active Member
alex.dring
Message 1 of 9 (318 Views)
Where used in drawing
318 Views, 8 Replies
12-25-2013 04:02 PM
Is there a way for me to somehow display what assembly uses a particular part?  For example I would like a part drawing to somehow inidicate what assembly drawing to refer to in order to show quanities required.
Can this be done?  Perhaps with ilogic which I know nothing about but will learn to get this to work. I am currently using standard Inventor 2012.
Thanks.
Look into iLogic in the help file.  I don't use it much, but there is a lot of power for automating routine tasks.
I can see making a custom iprop in your part templates, then making an ilogic rule in your iam templates to write the assembly file name/part number to each member of that assembly.  Then make a custom sketched symbol or title block field to show the custom iprop on your drawings.
What happens when you use the same part in five different parent assemblies...
blair
Message 2 of 9 (277 Views)
Re: Where used in drawing
12-26-2013 12:19 AM in reply to: alex.dring
If you are using Vault, it can be done inside Vault and in you are not using Vault, the the Design Assistant will show where a item is used.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
Active Member
alex.dring
Message 3 of 9 (264 Views)
12-26-2013 06:01 AM in reply to: alex.dring
I was actually looking for something that I could stick on the drawing.  Like a variable that automatically updates. It is more for our purchasing department as a check so they know what parent assembly drawing to look at in order to verify the correct quanitites should be ordered.
swalton
Message 4 of 9 (257 Views)
12-26-2013 06:56 AM in reply to: alex.dring
There is no out-of-the-box solution in Inventor.
Take a look at the Autodesk App Exchange for Invnetor for some Third-Party solutions.
http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3acpsjob...
http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3aquanti...
I have not used either one.
Good Luck.
Inventor 2014
Vault Professional 2014
Active Member
alex.dring
Message 5 of 9 (250 Views)
12-26-2013 08:16 AM in reply to: swalton
So how does one create programs like that?  Those almost do exactly what I want but instead of quantities I want it to show the drawing and/or part number that the assembly is.
Didn't even know about the app exchange.
swalton
Message 6 of 9 (245 Views)
12-26-2013 08:25 AM in reply to: alex.dring
Inventor 2014
Active Member
alex.dring
Message 7 of 9 (241 Views)
12-26-2013 08:29 AM in reply to: swalton
I will look into the iLogic.  Like you said there seems to be a lot of power in that.
For parts that are used in multiple assemblies I think it should just return a value of "Multiple or Various"
So basically you see like a time stamp in the drawing title block "Parent Assembly: (part or drawing number)
swalton
Message 8 of 9 (239 Views)
12-26-2013 08:30 AM in reply to: alex.dring
Another thing you might try:
1. Make your part idw.
2. Place a Parts List of the parent iam file in the part idw.
3. Hide all rows of the Parts List execpt the part shown in the idw.
       You can filter the list by design reps created in the iam file.
4. Change the title of the Parts List to show its source iam file.
5. Add a new Parts List for each iam file that uses the part.
Inventor 2014
Active Member
alex.dring
Message 9 of 9 (229 Views)
12-26-2013 08:43 AM in reply to: swalton
Thats a slick little work around swalton.  Thanks.
