Inventor Forum
Where to look up part count in assembly?
11 REPLIES 11
Message 1 of 12
eluoci
8311 Views, 11 Replies
Hi ! Where it be possible to look up part count in assembly?
Best Regards
11 REPLIES 11
Message 2 of 12
Mario428
in reply to: eluoci
In your assembly file under the "manage" tab is a "Bill of Materials" icon.
Click that icon, go to parts only tab and RMB the "Parts Only" icon and click enable, qty will be one of the columns
Message 3 of 12
eluoci
in reply to: Mario428
Thank you! Would you know if there is a way to see total parts count?
Message 4 of 12
mcgyvr
in reply to: eluoci
Bottom right corner of your screen shows "total occurances in active document"
Message 5 of 12
Mario428
in reply to: eluoci
The number you see under the "Parts Only" tab is the total number of parts in the assembly you are looking at.
The "Structured" tab shows you qty per subassembly if you use them
Message 6 of 12
Mario428
in reply to: mcgyvr
My screen does not show anything like that, is there a setting to enable it?
I see the number now but all it is is the total number of parts in my assy, an interesting number but very limited use, for me anyway.
I need the total number of each part for financial and planning purposes
Message 7 of 12
eluoci
I only have the total of the uniqe parts, but dotn have the total i am on inventor 2015
I do have this in the corner the first number seems to be the one, not sure whats the second one, but it doesnt correspond with uniqe part occurrence
Message 8 of 12
mcgyvr
I don't question why the OP needs the information.. Only provided the answer to where it is.. 🙂
And yes I agree the total number of parts in an assembly is virtually useless.
The BOM has all the needed information for you.
Message 9 of 12
mcgyvr
in reply to: eluoci
What do you mean "don't have the total".. Between the number in the bottom corner and the bill of materials (structured or parts only tab) you should have every number you would need.
The number on the bottom right is open documents in memory.. (including ALL open Inventor files and not just the current active window)
Message 10 of 12
Mario428
in reply to: eluoci
Total of subassemblies would also be included in the number at bottom right of screen.
Look at it as a file number count, assy's being a separate file of other parts.
As agreed it is a number but of very limited usage
Export your BOM and get Excel to do the count for you
Message 11 of 12
eluoci
in reply to: mcgyvr
I dont have total count off all the parts in the assbly in the Bill of Material quantity of each part used separetly but not the total, i enabled and chekced all tabs. only at the right bottom corner of the main window as you said.
Message 12 of 12
eluoci
i am meticulous with my lego parts 😃
