Inventor General Discussion
Distinguished Contributor
Karol-Or
Message 1 of 4 (195 Views)
Where is the select mode?
195 Views, 3 Replies
07-11-2013 09:27 AM
I want to change the selection method to feature priority.
Where is the button?
Not in the right click
Try Shift + right click (while not in any command, also try while in another command).
Too slow Chris - did you eat your Wheaties?
Curtis_Waguespack
Message 2 of 4 (191 Views)
Re: Where is the select mode?
07-11-2013 09:38 AM in reply to: Karol-Or
Hi Karol-Or,
It might vary depending on the version you using and the file type/ environment you're in, but look on the Quick Acess toobar along the top of the screen.
If you don't see this, then it might be helpful to provide more details on your version and the file type/ environment you're working in.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
JDMather
Message 3 of 4 (182 Views)
07-11-2013 09:44 AM in reply to: Karol-Or
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
cbenner
Message 4 of 4 (179 Views)
07-11-2013 09:45 AM in reply to: Curtis_Waguespack
Shift / Right Click... assuming you are in part or assembly mode.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
