I want to change the selection method to feature priority.
Where is the button?
Not in the right click
Solved by JDMather. Go to Solution.
Hi Karol-Or,
It might vary depending on the version you using and the file type/ environment you're in, but look on the Quick Acess toobar along the top of the screen.
If you don't see this, then it might be helpful to provide more details on your version and the file type/ environment you're working in.
I hope this helps.
Curtis
@Karol-Or wrote:Not in the right click
Try Shift + right click (while not in any command, also try while in another command).
Too slow Chris - did you eat your Wheaties?
Shift / Right Click... assuming you are in part or assembly mode.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
