Dear All,
who knows this XML files saved in which folder, and what the default file name? see the funciton dialog from attachment.
My Best Regards,
Rick
The column settings are stored in each assembly file.
RMB on a column and use the runtime customisation to add standard columns and use the add custom iproperties button at the top to add custom iproperties.
Set the column view to your preference and you can save those settings to an external xml file which is then available to import into another assembly.
If you will be using the same settings most of the time modify your template to store the correct columns so you don't have to import every time.
As far as I know there is no default file, there's only the default settings in the template.
