Inventor Forum
Where is shrinkwrap command in 2010
5 REPLIES 5
1310 Views, 5 Replies
I have turned off the ribbon UI and I cannot seem to find shrinkwrap now. Can anyone tell me another way to access this command?
Inventor 2010
5 REPLIES 5
mcgyvr
Assembly panel
johnsonshiue
The command is available in Assembly panel. Another way to access it is through right-click context menu in LOD. In an assembly file, go to browser->expand Representation node->right-click on Level of Detail->New Substitute->Shrinkwrap.
Thanks!
johnson.shiue@autodesk.com
Software Test Engineer
I am unable to get Inventor to 'load' Shrinkwrap at all. I am using 2010 and have installed the add-in by following the PDF directions. However, when I go to Tools>Customize>and then toolbars I am unable to see Shrinkwrap as an option and thus cannot load the toolbar. Does Shrinkwrap need to be installed in a specfiic directory to get Inventor to 'see' it??
mflayler2
If you are using the Shrinkwrap utility from Autodesk Labs, it is no longer needed. The funtionality is built in 2010.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
shekarsub[Autodesk]
The shrinkwrap utility on labs is old. Please use it only for R2009.
- The one on labs.autodesk.com dosen't work for 64-bit.
- During installation it asks for a directory to install the dlls in. If you don't enter it's filling the following for me: C:\Program Files\AutoDesk Shrinkwrap. The dlls can be anywhere as long as it is registered. Installing the download should register the dll for you automatically.
- It probably won't work on 2010 since it only works for 2009.
The shrinkwrap functionality in Inventor 2010 is new and improved (and different) and the one we recommend users to use.
Best regards
shekar
