Inventor Forum
WHats wrong with my computer?
8 REPLIES 8
Message 1 of 9
Infallable
550 Views, 8 Replies
I'm not particvularly well informed on the technical side of things, so feel free to ask any further details which I haven't provided.
My inventor runs incredibly slow all the tim (Inventor Professional 2013). Its basicly as simple as that - so slow that its almost unworkable.  I am working on a local server as opposed to my harddrive...could this be the reason?
Ive attached a snapshot of my system specs so you can see what my machine is running...
Drawings seem to be a lot slower than .idw and .iam files.
Thanks in advance for any advice you can provide
8 REPLIES 8
Message 2 of 9
in reply to: Infallable
Have you got inventor installed on the server or locally?
Are you running a vault server?
Chris Rodway
Design Engineer
Sheffield, UK
Message 3 of 9
Infallable
No, we're not running a vault server - I've been pushing it for ages but the IT guys aren't exactly 'pro-active ' on the issue!
Message 4 of 9
Infallable
Sorry, I didnt fully answer your question - Ive got inventor installed on my hard drive.
Message 5 of 9
ampster401
have you tried saving your files to your hard drive and working from there?
Message 6 of 9
If its local installed the problem could be your project file. Try making a new one by going into inventor projects creating a new project file
For your setup you need a single user project and select a local working folder to work out of
Hope this works and speeds it up for you, If not I'd recommend a re-install because your PC spec should be OK because mines worse and inventor and vault run fine. If you have to re-install make sure you delete the installation package out of C:/ Autodesk. This mean the installation is completely new
Hope this helps
Cheers
Chris Rodway
Design Engineer
Sheffield,UK
Message 7 of 9
cbenner
Message 8 of 9
blair
Possibly, it you have a slow network. Try copying files to your local machine, and create a new Project to point to the files on the local machine and see if performance improves.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 9 of 9
Infallable
in reply to: cbenner
Sorry, your right! My Graphics card is an ATI Radeon HD 4770.
