I have to fill out a space on a form for our company but I'm not sure what all files can be imported into Inventor. Is there a list somewhere?
Solved by Curtis_Waguespack. Go to Solution.
http://www.mcadforums.com/forums/viewtopic.php?f=5&t=11437
Hi zma1013,
I think the link that JDMather provided requires you to log in to view the attachment, so just in case you can't see it, here is another link:
http://blogs.rand.com/files/inventor-file-translations-2011-2013-2.pdf
Also, you can click the Open button and then click the drop down arrow in the Files of Type box, this will show you the file types Inventor can import.
I hope this helps.
Curtis
