style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<mr.thom> wrote in messageOk,
href="news:6057393@discussion.autodesk.com">news:6057393@discussion.autodesk.com...
I know that software writers use some completely different type of brain than
the rest of us seem to have, but why can't they at least give us a message
that is understandable? I know that this has been disscussed to death here,
but here I go with a new one. And I quote "Illegal attempt to create
identified child transaction inside an unidentified transaction".
???????????????? I am trying to place a constraint on two parts the same
constraint I have place on identical parts (all from the content center)
hundereds of times. What in the world does that message actuall mean to me?
Beats the heck out of me!! Anyone have any pearly words of wisdom to impart on
this cryptic message?? I will just be sitting here scratching my head till
that happens. Thanks Thom
"Steven Dennis (Autodesk)" <
href="mailto:steven.dennis@autodesk.com">steven.dennis@autodesk.com>
wrote in message
href="news:6057458@discussion.autodesk.com">news:6057458@discussion.autodesk.com...
Yes our brains do work different than most!
This message does make sense to us Inventor
developers. For this particular issue I'm not sure how we could make it more
"non-developer" friendly.
What it means is that our internal memory
mappings (for undo, etc.) have gotten confused.
I will have one of our QA guys try to get your
dataset from you, these issues are generally data set specific.
Steve Dennis
Autodesk Inventor Modeling Tech Lead
than the rest of us seem to have, but why can't they at least give us a
message that is understandable? I know that this has been disscussed to
death here, but here I go with a new one. And I quote "Illegal attempt to
create identified child transaction inside an unidentified transaction".
on this cryptic message?? I will just be sitting here scratching my head
till that happens. Thanks Thom
Any news on this issue. I keep getting this message which immediately precedes Inventor crashing.
Saw that the original post was the error when they were trying to create a constraint in an assembly. I have not seen that one BUT many, many, many times I will be creating an IPN, do the Tweak command, pick a direction, select some parts then try to drag them and I'll get :
Serious error - Illegal attempt to create identified child transaction inside an unidentified transaction. OK
and in the background at the same time I get another small window (usually covered by the first error window) stating :
Vault - <some part number> is currently locked. Do you want to continue editing anyway? Your changes will not get saved to Vault. YES - YES TO ALL - NO - NO TO ALL
If I click OK on the error window and NO on the locked window, the parts snap back to where they were and I cannot drag them. If I click OK on the error and then YES (or YES TO ALL if it's more then one part) then the parts snap back to where they were, I try the drag again and nothing moves, then I try it a third time and they drag and stay.
And not sure WHY Inventor thinks a part is somehow changing when you're tweaking it in an IPN. That's just (supposed to be) a view tool that I don't believe is actually supposed to touch any parts.
This is a pretty repeatable situation. The one I pulled up to get this example, the part causing the error was just created in the last couple days and about an hour ago it was checked in to Vault and changed to Released (and updated in my Workspace). This is a very common occurance and really puts a dent in productivity.
Just for reference were running INV 2012 64-bit, Build 219, Release 2012 SP2, Date Fri 04/27/2012 under Windows 7 Enterprise SP1. We're also running Collaboratoin so not sure how to look up what Version of Vault (in case that matters).
Why don't you developers stop adding things like the time wasting ribbon and fix all the bugs Inventor has.........
Still getting this issue in Inventor 2014 , had to files open at the time , got the message on a machine that was running the Job Processor for vault , but inventor didnt have any files open at the time, I have read that on the machines that are running the job processor that to help publish the Viz file it is better to have inventor open , since the JPadmin uses the inventor engine to help publish the viz file, but if I keep getting this error then I have to wonder what the point is.
see attachment
