Hello;
It seems to dim it as an arc; If you you drag the dim along the path of the arc it goes the entire length; Only when you locate the dim, does it change the measured value. An arc was created as the sketch in the sketch view and then projected onto the cylindrical path. So an arc on the path of a circle, but I still think it could be measured as an arc, because it's constant, not changing, like a spline that might have different values along it's path. Also I think if it wasn't constant, then before you'd click the dimension, it would give you some other readings as you drag it along the path. I would also think a fabricator, could take the arc, whether 29.577, or 29.583, and subtract the .011 and swing it from the center line of the arc. The whole idea, is for it to travel .011. The arc is the result of going from the one hole to the other, with a .011 rise. And if it's not a radius then shoudn't the software reject it, instead of clicking .005 different with a R.? Thanks for input though.
