Inventor General Discussion
Active Member
0 Kudos
Post 1 of 4
What's the fillet radius in this diagram? (file attached)
1034 Views, 3 Replies
12-10-2011 10:44 PM
Hi, I'm currently enrolled in a PLTW course in my local high school. We have a upcoming project that I decided to get a head start on. The problem is, the diagram the project gives out doesn't give clear dimensions how the radius of the fillet. I have attached two files, the work I've already done and the diagram. I've been looking over the diagram for the better part of the day and I still don't know the exact fillet radius I'm supposed to use. On one of the referenced radiuses, I entered in a figure that appeared to work.
The TYP note means Typical - that is - all the smaller radiii are 0.063 (probably a round off of .0625 since we can't hole fillets to 4 decimal places in manufacturing anyhow).
You are doing great.
Here is another way you might have created that part.
(don't for get to add the .0625 hole.
It wouldn't do you any good to see without a feature tree.
I made the part with 3 simple revolves.
1. for the wheel
2. for the pin (minus the hole)
3. for the spoke cut (cut angle - midplane 30°)
see attached image
2,128 Kudos
Post 2 of 4
Re: What's the fillet radius in this diagram? (file attached)
12-11-2011 06:41 AM in reply to: dong.kevin1
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
0 Kudos
Post 3 of 4
12-11-2011 01:40 PM in reply to: JDMather
Can you save the file in a different file format? I only have the 2011 version of Inventor since that's the version my school uses. I reccomend saving in the .sat file format.
2,128 Kudos
Post 4 of 4
12-11-2011 02:06 PM in reply to: dong.kevin1
1. for the wheel
see attached image
