I think you would get better luck in posting in 6.0 as it is a problem which
would apply to IV in general. Its probably been over looked here.
Sounds like a really good project, the modelling yes I am sure can be done,
the spread sheet thing I don't know but there are some keen guys in 6.0.
Laurence,
Power is nothing without Control
"JaNee" wrote in message
news:1961C171072EA305A890B4BD448F5248@in.WebX.maYIadrTaRb...
> We use plastic formwork components to assemble a house kit/mould.
> The kit is erected on site on a raft or strip footing
> All window frames and or winformers (to create the cavity is located) -
same
> with doorframes
> All water and electrical services are then mounted
> Steel reinforcing is placed at strategic points
> The mould is then cast/filled with an aerated mortar
> The following day the formwork is removed and re-erected to create a
> production line for mass housing
> What i need is a program that would be able to build any design house/wall
> into various formwork components
> The panels are made up of a basic combination of 4 components
> The walls must be created (option of two standard sizes)
> All this info to be dumped/ exported into a spreadsheet used to calculate
a
> cost estimate
> web info at www.moladi.co.za
> TIA
