Has anyone else noticed this? There is a clear photo including trees, a building and a parking lot clearly visible on the part when the appearance factor is set to 60 or more. How does one make this go away? I would rather not explain this everytime someone asks during a presentation.
Solved by Curtis_Waguespack. Go to Solution.
hi jleonard2500,
This link should be of interest:
http://inventortrenches.blogspot.com/2011/03/change-reflection-for-shiny-parts.html
I hope this helps.
Curtis
hi jleonard2500,
Here is the content of that link:
I hope this helps.
Curtis
Change Reflection for Shiny Parts
You can change it to use something more subtle such as the one called Chrome.
A good way to test each reflective environment file is to create a half circle and revolve it 360 degrees to form a sphere. This will allow you to see what the image contains or doesn't contain. Here the ParkingLot.dds shows one of the Autodesk developers on his motorcycle.
Thanks!
I dont recall having the issue of 'motorcycle dude' appearing in any of my Inventor drawings prior to 2020, i have been using since 2006; but see this is an old thread. Things like this (seeing this suddenly appearing in my reflective components) make me question Autodesks' decision calls.
I updated from 2019 to 2020 and when opened an existing file suddenly had a guy face/helmet/motorcycle smiling in all of my drawings. Stupid issues like this (along with revised GUI's) always make me regret upgrading.
Thank you for the solution!
James
Motorcycle guy has been present since at least 2017, which is the year I started using Inventor. I don't see it as much of a problem, because a reflective surface needs something to reflect. It's also really not an issue worth having regret over, seeing as you change one option in the settings and you don't have to worry about it again.
@thenottakenname wrote:
Motorcycle guy has been ....
Trivia question: What was it before the Motorcycle Guy?
A river landscape. 🙂
Not something that was "changed"...that goofy motorcycle guy has been in the reflection for the past 6-7 years I've been using Inventor.
