Inventor General Discussion
Valued Contributor
bms953
Message 21 of 25 (155 Views)
Re: what is this error???? and why happend ?
10-28-2012 12:27 PM in reply to: JDMather
after i See JDMather and karthur1 post,  i try to download SP1.1 and install that , redraw sketch in new part and put every panel in separate Block ( JDMather advise ) but when i want insert coincident betwen 2 point of Block again ........ look to pic
Behzad Meskini
freedom for Iran
Valued Contributor
bms953
Message 22 of 25 (153 Views)
10-28-2012 01:00 PM in reply to: bms953
my system configuration is :
CPU Core i7 3610 QM
VGA ; GForce GTX 660m
Ram : 8GB
HDD : 750 GB
WIN 7 Home Pre
Office 2003
i Update my Windows and Inventor SP
i want know has this error relationship with this config????
Behzad Meskini
freedom for Iran
Valued Contributor
bms953
Message 23 of 25 (147 Views)
10-28-2012 02:40 PM in reply to: karthur1
interesting , i download a sample file from this forum and try to change for find solution and again this **** error appear.
should i reinstall Inventor ??!!!???!!  :mansad:
Behzad Meskini
freedom for Iran
karthur1
Message 24 of 25 (110 Views)
10-29-2012 08:47 AM in reply to: bms953
Probably first try the repair install.  If that doesnt work you could do the reinstall.  Did you install SP1.1?
Valued Contributor
bms953
Message 25 of 25 (93 Views)
10-29-2012 09:48 AM in reply to: bms953
ok, tnx , yes i Install SP1.1
Behzad Meskini
freedom for Iran
