Inventor General Discussion
Active Contributor
5 Kudos
Post 1 of 4
what is the use of structured tab in BOM in iam???
293 Views, 3 Replies
06-06-2012 12:52 PM
Untitled.pngwhat is the use of this tab???
and what is the difference between structured and model data?
Hi shuaib_cad,
This is the 3rd time I've attempted to reply and add the further clarification you requested. Unfortunately, the moderators have had to remove some of your replies due to a lack of professional conduct, and therefore my replies were lost. Please remember to conduct yourself professionally, as this is a peer to peer help forum and everyone deserves respect, particularly those who are taking the time to offer you assistance.
As per the section in the help article I noted earlier, the Structured view of the BOM is an organized view of the assembly that differs from the Model view in a few key ways. First the Structured view does not display Reference and Phantom component structures, and any child components of a Phantom components will be promoted and will show in the Structured View.
Secondly, as you might have noticed the Model view contains no item numbers, where as the Structured view does number the item, and allows for those item numbers to be managed, by renumbering, sorting, etc.
More differences to know about:
  • The Structured view also contains some controls for displaying All Levels or only a single level.
  • The Structured view can be exported to an XLS, MDB, etc. but the Model View cannot.
  • The Structured view and Model view can contain different columns, allowing for you to customize views per your assembly template.
I hope this helps.
Curtis
Edit:
It looks like bobvdd has provided some more good information while I was retyping.
1,702 Kudos
Post 2 of 4
Re: what is the use of structured tab in BOM in iam???
06-06-2012 01:01 PM in reply to: shuaib_cad
Hi shuaib_cad,
The button indicated in this image should help you find your way through some of these things.
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0460-Assembli460/0530-Bills_of53...
(see Bill of Material Views)
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Product Support
47 Kudos
Post 3 of 4
06-06-2012 01:38 PM in reply to: Curtis_Waguespack
Some other good reading on the subject can be find on the support blog
http://beinginventive.typepad.com/being-inventive/2011/05/exporting-all-level-bom-from-inventor.html
Bob
1,702 Kudos
Post 4 of 4
06-06-2012 01:49 PM in reply to: Curtis_Waguespack
Hi shuaib_cad,
I hope this helps.
Curtis
Edit:
