Application Manager informed me to install it, and I did so.
But what does it fix?
Thanks for enlightenment
Walter
Walter Holzwarth
Solved by ChrisMitchell01. Go to Solution.
See the readme for additional information: http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-1-fo...
Mark Lancaster
& Autodesk Services MarketPlace Provider
Sorry my mistake... Update 1 for Inventor 2015 SP 1 is INV19110. Not sure I have heard about or seen Hot Fix INV19111. I did't find anything regarding that hot fix. Can you confirm it was INV19111?
Mark Lancaster
Hi Walter,
Whenever anything is pushed out through App Mgr, you can click on it to expand to get further information. In this case you would see:
If you then click "View Details" you will go to
http://download.autodesk.com/SWDLDDLM/Updates/Inventor/HotFix/INV19111.htm
Basically lines in DWF files for drawings created through a batch process such as on a vault job processor were not being created properly after installing 2015 SP1 Update1.
Chris
Aah, now I see. Thanks, Chris.
Old donkeys are learning slower ..
Walter Holzwarth
I was going by the Autodesk/Inventor/Support page... Its not listed there and I didn't have the hot fix listed in my Autodesk Application Manager. Odd...
Mark Lancaster
App Mgr is slightly ahead of what's on the support pages in terms of syncronization. This will appear there by tomorrow. App Mgr by default checks every 4hrs so depending on when it last checked you might have to wait a while.
-Chris
I still can not find any mention of this on the support page. Is there a direct link to the hotfix?
Kirk
I agree with Karthur1 – Still not available on the download page! Chris Mitchell – Can You Please post a Link to the HotFix here in the Forum – Since the Forum is also ahead of the Support pages…..– So I can Download it for my Users (Not all Users have access to the Internet/AppMgr – I know can you believe it!!!)
Sure for 2015:
Or for 2014:
The fixes were appended to the same pages as the last Updates since they were what caused the issue.
-Chris
@Anonymous wrote:
The Link you supplied takes me to INV19110.zip NOT INV19111.ZIP
INV19111 is on down toward the bottom of the INV19110 Update page. Thas a new twist on releasing an update.
Thanks Chris.
Kirk
