Inventor Forum
What If I'm forced to use non Inventor Nvidia OpenGL Application Setting?
2 REPLIES 2
brian.cranston
131 Views, 2 Replies
I have a separate OpenGL application that will not run if I have my Quadro 1400 set for the Inventor Application setting. Specifically, through testing, I found I have to use a Solidworks certified driver with the OpenGL application set to Solidworks. (no it's not SW I'm talking about- it is software call Photopia that is funky). What do I lose by setting my OpenGL application selection to Solidworks?
Thanks in advance,
-Brian Cranston
2 REPLIES 2
IV10 does *not* require or even benefit, that I know of, from using the "Inventor" setting. Don't know what version of IV you're using though...
http://www.inventor-certified.com/graphics/show.php?id=90&full=&limited=&none=&XP64=on&XP=on&2K=on&NT=&PCIe=on&AGP=on&PCI=&Chipset=on&query=NVIDIA&inventorVersion=R11.0&results=3
"For Autodesk Inventor® 10, Either the Nvidia default OpenGL setting or the Autodesk Inventor setting will work."
in reply to: brian.cranston
In the past it was actually recommended to set it to Solidworks. I'm not
sure there will be much difference.
Sean Dotson, PE
RND Automation & Engineering
www.RNDautomation.com
www.mcadforums.com
wrote in message news:5179512@discussion.autodesk.com...
Thanks in advance,
-Brian Cranston
