i could not extrude this four line CLOSED profile. it keep saying the profile is not closed. when i drew the fourth line, i moved the cursor to the first line starting end as close as i can and also watch the end trun yellowish. adding dimensions did not help.
thanks.
Solved by blair. Go to Solution.
Solved by admaiora. Go to Solution.
Your profile is not closed.(No coincident constraint at the ends)
You may have your coincident inference not selected.
Admaiora
i do not have the icon you circled in the ribbon. your INV version?
thanks.
ps. i got it fixed in constrains option window.
